Brief Description: Autopilot installation continued
Today I started by drilling the aileron bellcrank for the hole for the autopilot roll servo push rod. Then I assembled, safetied and installed the the roll servo in the wing. Next I completed the power and ground circuits for the autopilot and to finish off for the day I began soldering the autopilot control panel connector wiring to the connector pins.
Autopilot roll servo installation completed
Autopilot control panel connector harness wire installation started
